10-14-2004 06:39 AM - edited 03-02-2019 07:16 PM
Hi I've upgrade the MSFC card on the supervisor to MSFC2 but it doesn't recognize the new msfc2 card. I guess I did all in the right way but maybe I have missed one step. I upgraded the DRAM memory to 128MB, I upgraded the IOS to the cat6000-supk8.8-3-3.bin version I aligned the conectors in the supervisor engine, this is basycally what I did.
Can I get some help to solve my problem?
Thanks a lot
LP
es-plcdatacanter1> (enable) sh mod
Mod Slot Ports Module-Type Model Sub Status
2 2 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes ok
3 3 48 10/100BaseTX Ethernet WS-X6248-RJ-45 no other
4 4 48 10/100/1000BaseT Ethernet WS-X6548-GE-TX yes ok
5 5 8 1000BaseX Ethernet WS-X6408-GBIC no ok
6 6 8 1000BaseX Ethernet WS-X6408-GBIC no ok
Mod Module-Name Serial-Num
2 SAD0401051F
3 SAD035201LA
4 SAD083009DZ
5 JAB040205VJ
6 JAB040205X9
Mod MAC-Address(es) Hw Fw Sw
2 00-30-f2-70-30-66 to 00-30-f2-70-30-67 3.1 5.3(1) 8.3(3)
00-30-f2-70-30-64 to 00-30-f2-70-30-65
00-d0-00-a0-38-00 to 00-d0-00-a0-3b-ff
3 00-d0-bc-f2-a9-f8 to 00-d0-bc-f2-aa-27 1.1 4.2(0.24)V 8.3(3)
4 00-03-32-31-67-44 to 00-03-32-31-67-73 10.1 7.2(1) 8.3(3)
5 00-30-a3-38-52-1c to 00-30-a3-38-52-23 2.3 4.2(0.24)V 8.3(3)
6 00-30-a3-38-52-0c to 00-30-a3-38-52-13 2.3 4.2(0.24)V 8.3(3)
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw Sub-Sw
2 L3 Switching Engine WS-F6K-PFC SAD035202KK 1.0
4 Inline Power Module WS-F6K-VPWR-GE SAD08320A5P 1.1 1.1(1)
sh version
WS-C6509 Software, Version NmpSW: 8.3(3)
Copyright (c) 1995-2004 by Cisco Systems
NMP S/W compiled on Aug 9 2004, 02:27:17
System Bootstrap Version: 5.3(1)
System Boot Image File is 'bootflash:cat6000-supk8.8-3-3.bin'
System Configuration register is 0x102
Hardware Version: 2.0 Model: WS-C6509 Serial #: SCA040201D6
10-14-2004 06:58 AM
The MSFC2 might be in rommon. Issue a "switch console" from a console session and try to recover. The following page should help
10-14-2004 01:44 PM
Thanks a lot I've solved my problem. Now my prompt is somethinmg like Router(boot). How can I fix it?
Once again Thanks!
10-14-2004 01:49 PM
Issue a "dir bootflash:" and see if you have a IOS file which starts with file name "c6msfc2-xxxxxx.bin".
If you do, set a boot variable using command
conf t
boot system flash bootflash:c6msfc2-xxxxxx.bin
config-register 0x2102
end
wr mem
If you reload at this point, it should boot up with full functional IOS. If you do not have an IOS image in bootflash, TFTP one into the bootflash.
10-15-2004 07:18 AM
Once again thanks a lot for your time. I've solved my problems I really appreciate that! Muchas gracias
