Problem with ANIServer
elsie.leung
I am running LMS 2.1, RME 3.4 and CM 3.2 on WIN2K server SP2.
This is a fresh installation. I did stop and start crmtmgtd but no help.
Went to analyze ANIServer, I've got this :-
AniWrapper>>analyze(SYSTEM) Server Named: ANIServer4.1-sew08668 on port: 14004
In my JRM log; Unable to launch JVMCould not create the Java virtual machine. Could not create the Java virtual machine.
Thanks/Elsie
Can anyone help please?
Palani Mohan
What is the problem with ANI Server you are having?
Sincerely .. palani
jegrimm
Check to ensure you do not have multiple versions of Java on your host.
I did a BIG cleanup including uninstalled cw2k, got a crmlog.exe Access Denied. So reboot the server, manually deleted the crmlog.exe application.
Removed key from registery. Removed programs like JAVA 1.3.1 and Apache Services, rebooted. Installed CD One from fresh, then RME 3.4, then CM3.2, ran selftest, was okay. Tried to add a device to RME, same errors again.
I am flying blind here. Any help would be appreciated. Thanks/Elsie
