problem with WAN ip switching
gordons
We have 3 sites, with a 3640 at the central location, and a 2611 at each remote site.
We are running IP only across Frame-Relay.
From my station at the central site, I can ping the 3548s that are connected to the 2611s, but not the ethernet interfaces of the 2611 themselves.
Any thoughts as to why? The answer is probably obvious, but I just can't see it.
Thanks.
scarothe
Greetings:
Hmmmm...it is not so obvious.
- Are you doing "IP unnumbered".
- Could you put the config of the 3640 and one of the 2611's here. W
- What is the IP address and mask on the 3548 to that site.
- Could you also provided the IP addresses/Netmask of the other routers?
- Have you tried running a "debug ip packet" on the 2611 to see what you get?
Thanks...Steve
Hi, Steve.
Here is the config of the 3640 at our central site:
sh run
Building configuration...
Current configuration : 1627 bytes
! Last configuration change at 07:51:16 UTC Fri Apr 19 2002
! NVRAM config last updated at 07:51:19 UTC Fri Apr 19 2002
version 12.2
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname wan_3640
logging buffered 49152 debugging
logging rate-limit all 1
logging monitor informational
enable secret 5 $1$DMZK$HYTyo35pb4qXsF1.Zu9ea1
ip subnet-zero
no ip routing
no ip finger
no ip dhcp-client network-discovery
call rsvp-sync
interface FastEthernet0/0
ip address 130.120.111.19 255.255.0.0
no ip route-cache
no ip mroute-cache
shutdown
duplex auto
speed auto
bridge-group 1
interface Serial0/0
no ip address
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
shutdown
bridge-group 1
interface FastEthernet0/1
ip address 130.120.111.12 255.255.0.0
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
bridge-group 1
interface Serial0/1
no ip address
no ip route-cache
no ip mroute-cache
service-module t1 timeslots 1-24
frame-relay map bridge 115 broadcast
frame-relay map bridge 130 broadcast
frame-relay lmi-type ansi
bridge-group 1
ip classless
no ip http server
logging trap debugging
logging 130.120.150.12
bridge 1 protocol ieee
dial-peer cor custom
line con 0
transport input none
line aux 0
password 7 101F5F090F474359
login
modem InOut
modem autoconfigure type usr_sportster
transport input all
speed 115200
flowcontrol hardware
line vty 0 4
login
end
And here is the config of one of the 2611s:
version 12.0
hostname wdc_2611
enable secret **********
ip subnet-zero
no ip routing
interface Loopback0
no ip address
no ip directed-broadcast
no ip route-cache
no ip mroute-cache
interface Ethernet0/0
ip address 130.120.111.14 255.255.0.0
no ip route-cache
no ip mroute-cache
bridge-group 1
interface Serial0/0
no ip address
no ip route-cache
no ip mroute-cache
frame-relay map bridge 125 broadcast
bridge-group 1
interface Ethernet0/1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
ip classless
no ip http server
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipx permit
line con 0
line aux 0
password ******
login
modem InOut
modem autoconfigure discovery
transport input all
speed 115200
line vty 0 4
password ******
login
no scheduler allocate
What I can see is that you have enabled bridging on the Ethernet / WAN interfaces and in effect you are bridging IP. Any particular reason why you are bridging instead of routing IP over the WAN ??. Once you enable IP bridging on, the ip addressess on the interfaces have no effect, and are not pingable. Thats why you are able to ping the 3548 and not the 2611. Unless you any REAL NEED TO DO BRIDIGING (i dont see), you should just turn off bridging, because its messy and adding overhead.
