probleme with my 2511
yveskamo2002
hi guys!
l have my term server 2511 and l was tryng to recovery the password but at the rommon mode, l cannot have any access even when l do confreg 0x2142
he brings me tho this: transaction "CONFREG' domaine server  (172.16.15.30)  (172.44.244.10) (172.244.15.17).
what those this mean. l when to all process still cannot do this. please someone can help me solve this matter in oder to me to go forward my lab.
cadet alain
confreg 0x2142
Where did you enter this command?
what you see after look like  the symptom you see when entering wrong command in privileged mode and DNS lookup is not disabled( with no ip domain-lookup command) so the IOS thinks this is a hostname you want to telnet to and he tries to translate to IP by contacting DNS servers.
To recover a password and enter ROMMON you have to issue break sequence at startup and then in  ROMMON you can change config register setting  to 2142 and then reset.
Regards.
Alain.
