Problems with Cisco Router 836
we have a problem with the router 836 installation,
the dsl connect from the router 836 to the Internet service provider is up,
the connect from the PC to thr router 836 is up,
but the name resolution is not possible.
e.g.:
ping 66.102.9.104 -> works
ping www.google.de -> fails
Router-Status :
LAN SUMMARY
Interface Status : up
Interface IP Address : 10.10.10.2
Interface Subnet Mask : 255.0.0.0
DHCP Server Enabled : No
Primary DNS Server : Not configured (or 195.30.0.1) -> both does not work
Secondary DNS Server : Not configured (or 195.30.0.1) -> both does not work
WAN SUMMARY
WAN IP Address :217.224.211.63
Line Protocol : up
VPI/VCI Number : 1/32
PPP User Name : xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx0001@t-online.de
Automatic IP address : Yes
DSL UP Stream Speed : 160 kbps
DSL Down Stream Speed : 1184 kbps
VPN connection status : Down
can somebody help me
thanks for help, best, Ralf
csoans
I would suggest you contact your ISP and check to see if you have the right ip addresses for your DNS servers.
It looks more like a DNS issue than a router issue.
Chris
