Problems with etherchannel between 2970 and 3500xl
btenney
3500xl :
Version 12.0(5)WC10
2970:
Version 12.1(11)AX
I have four physical ports setup in group 1.
2970 CONFIG:
interface GigabitEthernet0/21-24
switchport mode access
no ip address
duplex full
speed 100
channel-group 1 mode on
3500XL CONFIG:
interface FastEthernet0/45-48
duplex full
speed 100
port group 1
ETHERCHANNEL SUMMARY 2970
sh etherchannel summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
R - Layer3 S - Layer2
u - unsuitable for bundling
U - port-channel in use
Group Port-channel Ports
1 Po1(SU) Gi0/21(P) Gi0/22(P) Gi0/23(P) Gi0/24(P)
ETHERCHANNEL SUMMARY FOR 3500XL
Flags: d - default D - down
I - in use
Group Ports
1 Fa0/46(D) Fa0/45(Dd) Fa0/48(D) Fa0/47(D)
Everything seems to be working with 2970 and data is definitly going through. I am telneting through connection and servers are plugged in.
3500xl shows interfaces being down and spanning tree in block state. I know the etherchannel is working but the 3500 says everything is down. Any help would be appreciated.
Brett
As you have connected just 1 port so have u erased the port-group config from port 48 on 3500xl. if u did so and still shpwing down, then I would suggest you to shut doen the port manually and do a no shut.
also try changing the ports on 350xl.
aashish C
10 Replies 10
Hello Brett,
your 2950 has the channel mode set to on, which means it only builds the channel when the other side is explicitly configured for it. Try and add the command:
switchport mode trunk
to the interface range on your 3500XL switch.
HTH,
Georg
Tried adding that command to the 3500xl interfaces and it did not make a difference. Since 2970 is set to mode access, I also tried changing mode to trunk on that. No difference. I just moved both switches back to mode access for now.
Everything is on vlan1. spanning tree shows forwarding on 2970 and blocked on 3500xl. interfaces w/port group see traffic on 2970 but none on 3500 which seems impossible since that is the only route I can take to telnet into 2970. All interfaces on 3500xl say down when the lights are green on all four interfaces. The green lights are blinking as well.
Check to see the the Native VLAN is set the same on both sides. It defaults to VLAN 1, but perhaps it was changed sometime in the past.
Good Luck
Scott
Thanks.
I double checked and they are both on vlan1. No trunking is required. 2970 says port-channel is up and up with span tree fwd. 3500xl is still saying everything is down even with green lights blinking and data going through. Even span tree says blk state.
Sh cdp neigh from 2970 sees 3500. output on 3500 doesnt see the 2970. Wierd.
Brett
aashish.c
Level 4
Level 4
Hi Brett,
Please send me the sh run configuration of both switches.
On 3500xl, I would like to confirm whether all the links are coming as BLK by STP or 1 of them is FWD. Kindly send me the sh span tree output for all the ports . 3500xl doesn`t do any negotiation for FEC.
I doubt that there is no FEC running, but the data is going through a normal link . Just to clear the functionality kindly remove any random link and check whether it shifts the load to other link or not.
also send me these from 2970 :
show etherchannel 1 detail
show etherchannel 1 port
show etherchannel 1 port-channel
aashish C
2950 (show run)
Current configuration : 1965 bytes
version 12.1
spanning-tree mode pvst
interface Port-channel1
no ip address
interface GigabitEthernet0/1
no ip address
no ip address
interface GigabitEthernet0/3
no ip address
interface GigabitEthernet0/4
no ip address
interface GigabitEthernet0/5
no ip address
interface GigabitEthernet0/6
no ip address
interface GigabitEthernet0/7
no ip address
interface GigabitEthernet0/8
no ip address
interface GigabitEthernet0/9
no ip address
interface GigabitEthernet0/10
no ip address
interface GigabitEthernet0/11
no ip address
interface GigabitEthernet0/12
no ip address
interface GigabitEthernet0/13
no ip address
interface GigabitEthernet0/14
no ip address
interface GigabitEthernet0/15
no ip address
interface GigabitEthernet0/16
no ip address
interface GigabitEthernet0/17
no ip address
interface GigabitEthernet0/18
no ip address
interface GigabitEthernet0/19
no ip address
interface GigabitEthernet0/20
no ip address
no switchport mode access
no ip address
duplex full
speed 100
no channel-group 1 mode on
interface GigabitEthernet0/22
no ip address
duplex full
speed 100
interface GigabitEthernet0/23
no ip address
duplex full
speed 100
interface GigabitEthernet0/24
no ip address
duplex full
speed 100
interface Vlan1
ip address 10.x.x.x 255.255.255.0
no ip route-cache
end
3500xl (show run)
Building configuration...
Current configuration:
version 12.0
no service pad
ip subnet-zero
cluster enable SLC_Cat_Cluster 0
cluster member 1 mac-address 0007.850a.6a00
cluster member 2 mac-address 0007.853e.2c80
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
duplex full
speed 100
interface FastEthernet0/5-42
interface FastEthernet0/43
interface FastEthernet0/44
duplex full
speed 100
port group 1
interface FastEthernet0/46
duplex full
speed 100
port group 1
interface FastEthernet0/47
duplex full
speed 100
port group 1
interface FastEthernet0/48
duplex full
speed 100
port group 1
interface VLAN1
ip address 10.x.x.x 255.255.192.0
no ip directed-broadcast
ip nat outside
ip default-gateway 10.x.x.x
ip nat inside source list 199 interface VLAN1 overload
access-list 199 dynamic Cluster-NAT permit ip any any
snmp-server engineID local 0000000902000007853E0840
snmp-server community convict@es0 RO
snmp-server community convict RO
snmp-server community guard RW
snmp-server community guard@es0 RW
sh etherchannel 1 detail
Group state = L2
Ports: 4 Maxports = 8
Port-channels: 1 Max Port-channels = 1
Ports in the group:
Port: Gi0/21
Port state = Up Mstr In-Bndl
Channel group = 1 Mode = On/FEC Gcchange = 0
Port-channel = Po1 GC = 0x00010001 Pseudo port-channel = Po1
Port index = 0 Load = 0x00
Age of the port in the current state: 00d:00h:01m:13s
Port: Gi0/22
Port: Gi0/23
Port: Gi0/24
Port-channels in the group:
Port-channel: Po1
Age of the Port-channel = 00d:00h:01m:17s
Logical slot/port = 10/1 Number of ports = 4
GC = 0x00010001 HotStandBy port = null
Port state = Port-channel Ag-Inuse
Ports in the Port-channel:
Index Load Port EC state
0 00 Gi0/21 on
0 00 Gi0/22 on
0 00 Gi0/23 on
0 00 Gi0/24 on
Time since last port bundled: 00d:00h:01m:13s Gi0/24
sh etherchannel 1 port
Ports in the group:
Port: Gi0/21
Age of the port in the current state: 00d:00h:01m:38s
Port: Gi0/22
Port: Gi0/23
Port: Gi0/24
sh etherchannel 1 port-channel
Port-channel: Po1
Age of the Port-channel = 00d:00h:03m:11s
0 00 Gi0/21 on
0 00 Gi0/22 on
0 00 Gi0/23 on
0 00 Gi0/24 on
Time since last port bundled: 00d:00h:03m:06s Gi0/24
I took the etherchannel down so thats why its only been up for 3 min. Transfers were going very slow. I had the same problem with just 1 crossover and no etherchannel config. Link was showing down on 3500 with just crossover. Wondering if the clustering is causing problems. Not really sure what is going on.
btenney
UPDATE: 8/17/04
I took out all fast ethernet configs. I am only using a crossover with hard set speed. The int is still showing down and spanning tree blocked on the port 48 on 3500xl. The light is blinking green and data is going across since I am able to telnet.
aashish C
