Problems with HSRP or IOS ?
hannes.kunz
i have two CISCO 3620 (IOS: c3620-is-mz.122-27.bin) connected over a switched LAN and both configured with a hsrp group.
i always receive following message:
%STANDBY-3-DUPADDR: Duplicate address 10.254.144.253 on FastEthernet0/0, source
d by 0000.0c07.ac01
the ip address in the error-message is the routers own ip adress of the lan interface
it seems to be the same problem which is documented on CCO:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094afd.shtml#t12
in the document the message may be due SPT loops...
but if i connect the both routers directly with a cross-over cable the message appears again.
so it can´t be a problem of the switched LAN (SPT or something else..)
another strange thing:
when i execute a "show cdp neighbor neighbor" on Router A then i see Router A appearing as the neighbor !!
The router sees itself in the cdp table ?!
Is this a IOS bug ?
any ideas.
thx
hannes
alagrawa
Level 3
Level 3
Hi Hannes,
Your symptoms definitely looks like a bug. Both CDP and HSRP use multicast. It looks like multicast packets are being looped back on fas0/0. Are you able to ping from one router to the other without any issues?
I did a quick bug search but havent found anything. I am aware of a bug CSCef13690 which causes multicast and broadcast traffic to get looped back if a port on the NM-2FE2W-V2 etherswitch module is configured as 10/half.
If noone else responds, I would recommend opening a case with TAC to get a bug identified.
regards
-Alok
