Python For Looping
alfredobosca
Level 3
Level 3
Hi folks,
After Cisco Live 2020 I decided to boost my learning about Python and I begun to write my first functions and brief code.
Now I tried to create a for looping for accessing all Cisco devices included in a list called: device_list but 'm getting next issue:
net_connect = Netmiko(**devices[i])
File "C:\Users\abosca\PycharmProjects\Python_Course\venv\lib\site-packages\netmiko\ssh_dispatcher.py", line 252, in ConnectHandler
return ConnectionClass(*args, **kwargs)
TypeError: __init__() got an unexpected keyword argument 'assword'
Code:
import os
import datetime
from netmiko import ConnectHandler
from netmiko import Netmiko
from dnac_resources import cisco_CSRV1, cisco_CSRV2
from dnac_functions import abosca_length
#Create de LIST of devices
devices = [cisco_CSRV1, cisco_CSRV2]
for i in range (len(devices)):
    print("The number of Devices is:", len(devices))
    print(devices[i])
    #net_connect = Netmiko(**cisco_CSRV1)
    output = net_connect.send_command("show ip int brief")
    print(output)
By the way, If I'm not using for looping I can access correctly to cisco devices.
Many thanks,
Jon Marshall
The error message is telling you the problem, you must have a typo in your device file ie. instead of "password" you have "assword" so check your file.
Also as a suggestion your for loop could be
for device in devices:
     net_connect = ConnectHandler(**device)
     print(output)
unless you want to print out the same length each time through the loop ?
Jon
KRUNAL LATHIYA
Community Member
Here's the revised version of your code with the proper for loop and import statement:
import datetime
# Create the list of devices
# Print the number of devices (outside the loop)
    try:
        # Establish a connection to the device
        net_connect = Netmiko(**device)
        print(device)
        # Send command and print the output
        print(output)
    except Exception as e:
        print(f"An error occurred: {e}")
    finally:
        # Disconnect from the device
        net_connect.disconnect()
