qos issue
chenleish
if one of my customers want to qos and wish I can guarantee all of his application to go around in my network. can I promise him? I think i can only assure his outside traffic , i can mark it and do some qos policy, but for inside trafiic , I have no way to do. right?
thisisshanky
Level 11
Level 11
Traffic going outbound can be definitely guaranteed during congestion using CBWFQ or LLQ. You can even classify packets and mark packets based on DSCP or IP. Typically you apply this policy on the outbound serial interfaces connecting to an IP WAN.
For traffic coming inbound you could mark the inbound packets based on DSCP/Precedence (apply the service-policy on the lan interface in the outbound direction. Your internal LAN switches or other routers can use these marked (classified) packets for QOS in the LAN. Essentially using Outbound QOS policy maps you can achieve Outbound and Inbound QOS.
policy-map Outbound
class Voice
priority 512
class Data
bandwidth 256
int s0
service-policy output Outbound
int e0
service-policy output Inbound
policy-map Inbound
class Voice
set cos 5
class Data
set cos 3
(These cos values are set at the router and the internal equipments - Lan switches/Routers can use these marked packets for further QOS)
Hope that helps!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
maybe I didn't explain clearly.
em.......
let's suppose we have A user who want us to offer QOS for all his application, and b,c,d.....zzz user (thousands of them) doesn't want qos .
then A want to ftp-get from b,c,d....zzz, we can marking the packets from A base on dcsp for example.
but for packets to A, how we do? marking it on the PE which connect to b,c,d...zzz base on destination IP address?
so what if there are many qos user and nonqos user?
that will be a terrible job!
no one know?
