Question on cisco prime, continuously losing connection to devices after config deployment
hhhax7
I am currently running a bunch of config deployments to a large group of switches. Every time I run one and get ready to run the next one, I would say about half of my devices lose connectivity. After a few minutes, everything comes back up and I can run the next deployment, but this delay is seriously slowing me down.
Anyone ever run into this issue before? I have reachability to the devices, but it says "SNMP connectivity failed". I don't believe its an issue with the password, because we have not changed anything there, and it does regain connection after a few minutes. Any other ideas?
pieterh
you may run out of some resources on the appliance
- how much is "a large group" ?
- how much devices in total
- do you have a hardware appliance or a virtual appliance?
- large medium or small CPI installation
you may set a maximum in parallel or even try deploying sequential instead of parallel
Large group consists of 50-70 switches (3750x)
Total devices is the same, running on all devices
Virtual appliance
