10-09-2005 05:04 AM - edited 03-03-2019 12:18 AM
I recently installed one Cisco 1711 and two Cisco 831 routers. Every time I boot them I get the error: SYSTEM INIT: INSUFFICIENT MEMORY TO BOOT THE IMAGE! and the routers boot process is started again. This happens every time, either during a cold boot or a reload. Once the router reloads/boots after the memory error, it then loads/boots again and operates normally. The Cisco 1711 router is running IOS version: c1700-k9o3sy7-mz.123-8.YG2.bin, while the Cisco 831 router's are running c831-k9o3sy6-mz.123-8.T11.bin. The memory in both units are as follows:
Cisco 1711
rommon 1> meminfo
Main memory size: 96 MB.
Available main memory starts at 0x10000, size 98240KB
IO (packet) memory size: 10 percent of main memory.
NVRAM size: 32KB
show version>
Processor board ID FOC09171D4P (4019070913), with hardware revision 0000
MPC862P processor: part number 7, mask 0
1 Ethernet interface
5 FastEthernet interfaces
1 Serial interface
1 terminal line
1 Virtual Private Network (VPN) Module
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Cisco 831
rommon 1> meminfo
System Bootstrap, Version 12.2(11r)YV3, RELEASE SOFTWARE (fc2)
(Virtual Configuration Register: 0x2102)
Main memory size: 64 MB.
Available main memory starts at 0x1b000, size 65428KB
NVRAM size: 128KB
show version>
Cisco C831 (MPC857DSL) processor (revision 0x500) with 58983K/6553K bytes of memory.
Processor board ID FHK091722X9 (357535429), with hardware revision 0000
CPU rev number 7
2 Ethernet interfaces
4 FastEthernet interfaces
128K bytes of NVRAM.
16384K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
Can anyone tell me why this is happening? I included two attachment files,one for the 1711 and one for the 831 router. Both show the boot sequence and what happens. I also include router crash dump from the 831 router.
10-09-2005 01:47 PM
This is totally unrelated to your issue, but I noticed that c1700-k9o3sy7-mz.123-8.YG2 is deferred, you should go to c1700-k9o3sy7-mz.123-8.YG3:
10-09-2005 02:27 PM
Yep.. just upgraded to c1700-k9o3sy7-mz.123-8.YG3.bin" and see the same thing.
