RAS solution
erodadi
Dear all,
I need your sugestion regarding RAS solution, here i s my situation.
I have one router 3660 as backup for WAN router (turn off condition) and i want to utilize it as RAS to replace router 2509.
In my opinion to deploy it, i need to buy several component as follows:
- 30 Port Digital Modem Network Module (NM-30DM); 1 EA
- 1-Port Channelized T1/ISDN-PRI with CSU Network Module (NM-1CT1-CSU); 1 EA
I have several question:
1. Is the router 3660 work well as RAS with those additional component?
2. Are there any component do i need?
3. compare to dedicated RAS such as AS-5350, which is better?
Edo
spremkumar
Level 9
Level 9
In my working place we are using 3660 as a RAS but only for ISDN dial in connections since i dont have any digital modem NM installed in tht and it works fine.
Authentication being taken care by radius also with local authentication.
We r using the same since we have got some of our wan links connected to tht 3660.
i hope it shuld suit ur requirment too but again u need to have the ios and other H/W compatibilities to serve ur purpose.
regds
