Replacement of EICON CARD with CISCO Router
santanudey
To connect to Host in a X25 network from an IP network EICON Card is used, Can we use Cisco Router instead, if yes how??
umedryk
Level 5
Level 5
Absolutely, you can use the Cisco Router in this scenario. see the link for more inormation :http://www.cisco.com/pcgi-bin/Support/browse/psp_view.pl?p=Technologies:X25&viewall=true
application uses an API to interact with ECLAN Client
in that case how to use cisco router?
I need to implement a failover solution so I need a router.
