Router and Switch Model required complied with Specs
siddindia
Could anyone share Cisco Router and Switch Models as per below specs.
Routers with Minimum 8 Ethernet ports (1Gbps) & 4 FC Ports)Manufacturer
 Model No
 FunctionsHigh performance Routing for data exchange between data centres, remote WorkStation, DCU, Internet cloud.
 Routing CapabilityLayer -2 & Layer-3 routing & Dynamic discovery of routing
 Processing capacity Minimum 2 Mbps
 Features to supportQoS, MPLS, Security, Broadband, Multiservice, Voice, IP to IP Gateway
 Routing protocolsEIGRP, IGRP, IS-IS, OSPF, BGP, ARP, IPCP, IP forwarding, VLAN & MPLS etc.
 Network protocols TCP/IP, IPv6, IPv4, OSI, Telnet, UDP, DHCP
 Network management Using SNMP Protocol
 Inbuilt security featuresa. Data encryption supported DES (56 BITS) 3des SHA-1,
  b. Filtering of packets based on Source address,Destination address, Protocol type, User, Port number, URL
  c. Filtering of Protocols such as FTP, SMTP, HTTP,SNMP, UDP, ICMP, RPC, DNS, DHCP, ARP
  d. Minimum 100 IPSec VPN tunnels support
  e. Detailed system logging
 Speed configurability at each portAll ports shall be configurable from 64kbps to 2Mbps
 Interface ports 1000 Mbps LAN ports – 2 v V.35/G.703 Ports as per the system requirement. There shall be 50% spare ports.
 Mounting Rack mountable
LAN switch (24 port 1/1/1 Mbps, Layer 3 switching, 8 Ethernet ports(1Gbps))Manufacturer
 Model No
 Functions24 ports for connecting Workstation, servers, screen & peripheral devices on Local Area Network (LAN).
 Conform to standards ISO8802 or IEEE 802 Series Standards
 Switching capability Layer-3 switching & VLAN
 Interface ports ** Minimum 8- 1Gbps Ethernet ports
 Cable standard Cat 6 or higher bandwidth cable
Ganesh Hariharan
Check out the comparison link for cisco 4000 series routers and you can decided based on your requirement.
http://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
For switches, You can go with cisco 3560 or 3750 series with routing capability.
Hope That Helps..
-GI
Rate if it Helps..
