07-24-2015 06:08 AM - edited 03-03-2019 07:56 AM
Could anyone share Cisco Router and Switch Models as per below specs.
Routers with Minimum 8 Ethernet ports (1Gbps) & 4 FC Ports) | Manufacturer | |
Model No | ||
Functions | High performance Routing for data exchange between data centres, remote WorkStation, DCU, Internet cloud. | |
Routing Capability | Layer -2 & Layer-3 routing & Dynamic discovery of routing | |
Processing capacity | Minimum 2 Mbps | |
Features to support | QoS, MPLS, Security, Broadband, Multiservice, Voice, IP to IP Gateway | |
Routing protocols | EIGRP, IGRP, IS-IS, OSPF, BGP, ARP, IPCP, IP forwarding, VLAN & MPLS etc. | |
Network protocols | TCP/IP, IPv6, IPv4, OSI, Telnet, UDP, DHCP | |
Network management | Using SNMP Protocol | |
Inbuilt security features | a. Data encryption supported DES (56 BITS) 3des SHA-1, | |
b. Filtering of packets based on Source address,Destination address, Protocol type, User, Port number, URL | ||
c. Filtering of Protocols such as FTP, SMTP, HTTP,SNMP, UDP, ICMP, RPC, DNS, DHCP, ARP | ||
d. Minimum 100 IPSec VPN tunnels support | ||
e. Detailed system logging | ||
Speed configurability at each port | All ports shall be configurable from 64kbps to 2Mbps | |
Interface ports | 1000 Mbps LAN ports – 2 v V.35/G.703 Ports as per the system requirement. There shall be 50% spare ports. | |
Mounting | Rack mountable | |
LAN switch (24 port 1/1/1 Mbps, Layer 3 switching, 8 Ethernet ports(1Gbps)) | Manufacturer | |
Model No | ||
Functions | 24 ports for connecting Workstation, servers, screen & peripheral devices on Local Area Network (LAN). | |
Conform to standards | ISO8802 or IEEE 802 Series Standards | |
Switching capability | Layer-3 switching & VLAN | |
Interface ports | ** Minimum 8- 1Gbps Ethernet ports | |
Cable standard | Cat 6 or higher bandwidth cable | |
09-25-2015 06:03 AM
Check out the comparison link for cisco 4000 series routers and you can decided based on your requirement.
http://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
For switches, You can go with cisco 3560 or 3750 series with routing capability.
Hope That Helps..
-GI
Rate if it Helps..
