Serial interface problem
manumohan200
Level 4
Level 4
I have connected a 4000 series router and a 2500 series routers serially using a back-to-back serial cable.The problem is that the line protocol never comes up.I am attaching the outputs here.Please help.
2500 series router outputs
2500#show interfaces serial 1
Serial1 is down, line protocol is down
Hardware is HD64570
Internet address is 10.0.0.1/8
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1158 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 39 interface resets
0 carrier transitions
DCD=down DSR=down DTR=up RTS=up CTS=up
2500#debug serial interface
Serial network interface debugging is on
2500(config)#int s 1
2500(config-if)#shut
2500(config-if)#no shut
2500(config-if)#
%LINK-3-UPDOWN: Interface Serial1, changed state to down
%LINK-3-UPDOWN: Interface Serial1, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state to up
2500#
Serial1: attempting to restart
HD(1): Deasserting DTR and RTS
HD(1): Reset from 0x3087208
HD(1): Asserting DTR
HD(1): Deasserting LTST
HD(1): Asserting DTR and RTS
HD(0): New serial state = 0x0600
HD(0): Cable is unplugged.
HD(1): got an interrupt state = 0x815A
HD(1): New serial state = 0x015A
HD(1): DCD is down.
%LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1, changed state to down
4000 series router outputs.
4000#show interfaces serial 1
Serial1 is up, line protocol is down
Hardware is HD64570
Internet address is 10.0.0.2 255.0.0.0
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input never, output 0:00:00, output hang never
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
88 packets output, 3188 bytes, 0 underruns
0 output errors, 0 collisions, 27 interface resets, 0 restarts
54 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
4000#debug serial interface
4000#
Serial1: HDLC myseq 12, mineseen 0, yourseen 0, line down
HD(1): Reset from 0x2F080
HD(1): New serial modem register = 0x019F
HD(1): DTR is up.
Serial1: HDLC myseq 13, mineseen 0, yourseen 0, line down
Serial1: HDLC myseq 14, mineseen 0, yourseen 0, line down
HD(1): New serial modem register = 0x019D
HD(1): DTR is up.
HD(1): New serial modem register = 0x0198
HD(1): DTR is down.
HD(1): DTR is up.
HD(1): DTR is up.
Serial1: HDLC myseq 15, mineseen 0, yourseen 0, line down
vmiller
Level 11
Level 11
I cannot tell by looking but do a show controllers on both serial interfaces,one needs to be DCE, with a clockrate (not the same as bandwidth) set.
you also need a DCE cable connected to the DTE cable.
amorgos
Community Member
what is the conf of the two connected interfaces ?
Show contr int... would also be helpfull.
ramirogarza
Community Member
try the following simple configs on your routers:
on the 2500:
int s1
ip add 10.0.0.1 255.0.0.0
clock rate 64000 (use this command only if this is the dce side of the cable)
no shut
on the 4000
int s1
ip add 10.0.0.2 255.0.0.0
no shut
the line and protocol should come right up on both intfs once you issue the no shut
if it doesn't than you're not using the correct cable, you have a cable problem (defective, not plugged in properly, etc.), or there could also be a problem with one of your routers serial interfaces
Check the following link for more info on troubleshooting serial interfaces:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1915.htm#xtocid12
