Serial port with Built in CSU for Split T1
gilson_machado
I have a serial card with built in CSU and I want to split the T1 in two links of 768Kbps. Is that possible? Do you have a configuration sample?
Thanks in advance!
Hi Josef.
Thanks. This is what I was looking for.
Do you have any sample configuration for a fractional T1 divided in two ports of 768Kbps?
In other words, The WIC-T1 card will receive the connection for the T1 from the carrier and the rotuers does the separation of two intefaces of 786Kbps.
