ServerTech Redundant Power Units
thessick
Does anyone have any experience with these or this type of power load balancing product?
Tom
Patrick Laidlaw
Level 4
Level 4
Tom,
I don't have any experince with this particular Vendor, but several of my customers are using the APC monitored PDU's that give you the ability to load balance across phases keeping there racks properly load balanced. They have found that the ability to turn off a server has been really useful as most of there engineers are part of a work from home program.
Patrick
