Setting up a trunk connection between 2 - 6500s
JUSTIN LOUCKS
I was wondering what I need to do to properly configure the two GB interfaces on the sup. engines of a pair of 6500s to have them work properly as one pipe between the two. I am not real familiar with the proper syntax on CatOS and was hoping someone could give me some feedback on this.
Do I need to use the 'set port channel' and 'set trunk' commands? Anything else?
Any assistance would be appreciated.
amit-singh
Level 8
Level 8
You can connect the 2 switches using the etherchannel with the 2GB ports.You need to use only the Set port channel command if you have a flat network only with one VLAN. If you have multiple Vlan then define the ports as the trunk ports.
Please cehck the link below:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_8_1/confg_gd/channel.htm
HTH,
-amit singh
