sfp error or other problem?
ngo duyen
Users told that network is slow so we need to test network
sw2960 is access switch, vtp client; sw6509 is core switch, vtp server.
If I use the Pc ping an ip address in SW6509, It lost 3->6% packets (disconnect Trunk3 connection)
If I use the Pc ping an ip address in SW6509, I work well (disconnect trunk1 connection).
And if I replace sfp1 of the trunk1  of SW2960-01 with the good one, It work well.
So I think sfp1 have problem and I send it to cisco waranty.
But when I got sfp from Cisco, I test again and the same problem happened.
Test for long time I send sfp to cisco again. The second times I receive sfp from Cisco, test and get error again.
At this time, I dont know what happen with the device. Could u tell me how to identify problem?
thank you
paolo bevilacqua
Likely faulty or marginal fiber.
hi Paolo,
marginal fiber?
How to resol this problem?
thank you for reply.
anyone can help me ?
