10-25-2004 06:25 AM - edited 03-02-2019 07:30 PM
I'm sure this is something very simple, but when I ssh to a 6509 from my Linux machine and do a sh tech, the output gets down almost to the end, but then requires me to hit return at least a dozen times for each additional page to display. I've tried this with/without entering term len 0 before running the show tech command. It first requires a carriage return at this line:
------------------ remote command switch show process memory ------------------
I've tried this both on my Linux machine and my Windows machine and both are responding this way.
Any ideas?
10-29-2004 12:23 PM
Could you please try with another SSH client.
10-29-2004 02:36 PM
Tried on my Windows client using both Putty and QVT/Term. Both stop at the same place.
10-29-2004 03:05 PM
I have seen similar issue seen by other customers with ssh version 2. This issue has been fixed through the following bug
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCec67602
Upgrade to an IOS which has a fix for this bug
