Simple routing question
ralph.collins
I have a simple test setup :
<computer1>-<router1>-<router2>-<Hub>-<computer2>
<SMC router>--<internet>
(The SMC router is also connected to the hub)
Both routers are 2501's running RIP V2. The routing tables look fine. I can ping back and fourth between the two computers but I cannot ping the SMC router. I tried the 0.0.0.0 route entry but it doesn't seem to work. What am I missing? My plan is to have computer1 be able to access the internet through the SMC router.
Here are the configs:
Router 1:
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
hostname Router2
enable secret xxxx
enable password password
ip subnet-zero
process-max-time 200
interface Ethernet0
ip address 192.168.5.1 255.255.255.0
no ip directed-broadcast
interface Serial0
ip address 192.168.100.1 255.255.255.0
interface Serial1
ip address 192.168.4.2 255.255.255.0
encapsulation frame-relay
shutdown
frame-relay interface-dlci 105
router rip
version 2
network 192.168.5.0
network 192.168.100.0
ip classless
snmp-server community public RO
line con 0
transport input none
line aux 0
line vty 0 4
password test
login
end
Router 2:
version 12.0
hostname Router2
enable secret xxxx
ip subnet-zero
interface Ethernet0
interface Serial0
interface Serial1
shutdown
router rip
version 2
network 192.168.5.0
ip classless
line con 0
line aux 0
line vty 0 4
password test
login
end
10 Replies 10
Hello Ralph,
I think you accidentally posted the config of Router2 twice. Can you post the config of Router1, as well as of the SMC router ? The SMC router is connected to the same hub as Computer2 and Router2 ?
GP
Richard Burts
Ralph
You appear to have pasted the same config twice (at least both configs have the same host hame and have exactly the same IP addresses on the interfaces). Perhaps you need to try again.
If you can ping between the PCs then that is a good indication that routing within your small network is working ok. If you can not ping the SMC there are a couple of things that occur to me that may cause this:
- SMC may be configured to not respond to pings (lots of routers connected to the Internet disable ping).
SMC router may not have a proper route back to your machines.
- SMC router may have an address other than the one that you think that it is.
- SMC router may think the address on your routers is different than what you have configured. Lots of edge routers like to do DHCP for addresses for inside machines. Perhaps SMC is expecting your routers to generate DHCP requests, which they will not do with addresses configured.
You might check on these things and if it still does not work then post the right configs.
Do you have administrative access to the SMC?
Rick
Rick
Rick, I pasted the correct config this time.
But first..
- I can ping the SMC from another computer on the hub.
- I looked at the configuration on the SMC and don't see any way of giving it a path back to the router.
- As far as the SMC expecting a DHCP request, how would I set the router up for that?
Here's the configs...
Router 1
version 12.0
service udp-small-servers
service tcp-small-servers
hostname Router1
enable password test
ip subnet-zero
interface Ethernet0
ip address 192.168.2.75 255.255.255.0
no ip mroute-cache
interface Serial0
ip address 192.168.100.3 255.255.255.0
no ip mroute-cache
clockrate 500000
interface Serial1
no ip address
no ip mroute-cache
shutdown
router rip
version 2
network 192.168.2.0
ip classless
line con 0
line aux 0
transport input all
line vty 0 4
password test
login
end
Router 2
version 12.0
hostname Router2
enable secret xxxx
ip subnet-zero
interface Ethernet0
interface Serial0
interface Serial1
shutdown
router rip
version 2
network 192.168.5.0
ip classless
line con 0
line aux 0
line vty 0 4
password test
login
end
Thanks for the help
Ralph
Rick, I noticed that if I ping from within router2, (thats the one that is connected to the hub with the SMC) I get responses from the SMC router. I can't do that from router1. If that helps.
Ralph
The SMC router doesn't have a route back to router1. To be exact, the SMC router has only 2 routes, a 0.0.0.0 route to the internet and a directly connected route to 192.168.5.0. That is why it possible to ping it only from computer2 and router2 because they are directly connected on the same subnet. The SMC router is not aware of subnet 192.168.2.0
If it is not possible to add a static route on the SMC to subnet 192.168.2.0 (computer1 and router1's eth interface), then you may want to consider NAT'ing that subnet on router2:
interface Ethernet0
ip nat outside
interface Serial0
ip nat inside
ip nat pool blah_blah_pool 192.168.5.2 192.168.5.254 prefix 24
ip nat inside source list 5 blah_blah_pool
access-list 5 permit 192.168.2.0 0.0.0.255
*** you may need to tweak the NAT/access-list to avoid re-using the existing ip addresses on subnet 192.168.5.0
Mustafa
Mustafa, Thanks that makes sense. I'll give that a shot.
Ralph
If i am not wrong, NAT May not be of great help in Cisco 2501 Router.It might overload the router if Internet Traffic is more from/to Router 1.
Do u ve a proper Internet Firewall in place. If there is no Firewall, it might result in excess of unwanted packet hits to the network.This will in turn choke ur Internet Bandwidth.
This will reflect on the performance of the Router.
Please revert for further inputs.
Nirmal.
vnirmal112
NAT Will not be a viable option.Please give a static reverse route and assign access-lists to respective interfaces,thereby preventing unwanted packets to enter the network.
Nirmal.
dataline
Yeah Agreed with Mr.Nirmal.Ff u are having acsess to SMC router plz put reverse static route for router 1's subnet OR host based routing for both Router 1 & pc1.
Ok, all set. The SMC didn't allow for adding static routes or rip. I found a netgear router lying around that did. I set it up for RIP on the LAN side and it all went to work. I appreciate all of the help!
