Slow connection
jwright182
I seem to be haveing a little bit of trouble with my dial in access server.
I am able to dial in vi ISDN to my 2509 at 64K and create a vpn tunnel between two netscreen firewalls but the application I am trying to run go very very slow (vnc MS terminal server) If I log in to the 2509 with a pstn line at 33.6 everything is ok can anyone point me in the right direction!!!!
can you do a traceroute and see where the delay occurs ? There also is a utility called PingPlotter, downloadable at www.pingplotter.com which lets you detect which hop is actually causing a delay.
Can you post the configuration of the 2509 ?
Georg
Hi thanks for your replay here is some more info
Tracing route to 172.30.0.23 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 192.168.0.1
2 * 104 ms 103 ms 172.30.0.251
3 112 ms 113 ms 112 ms 172.30.0.23
Trace complete.
Hop 1 is my netscreen 5gt which dials the cisco
hop 2 is my netscreen 208 at the other end of the cisco 2509
hop 3 is server I am trying to access
Some more debug stuff
Router(config-line)#modem autoconfigure discovery
*Mar 9 19:19:44.455: TTY3: autoconfigure probe started
*Mar 9 19:19:45.139: TTY3: detection speed (115200) response ---OK---
*Mar 9 19:19:51.751: TTY3: Modem type is default
*Mar 9 19:19:51.755: TTY3: Modem command: --AT&F&C1&D2S0=1H0--
*Mar 9 19:19:52.459: TTY3: Modem configuration succeeded
*Mar 9 19:19:52.459: TTY3: Detected modem speed 115200
*Mar 9 19:19:52.463: TTY3: Done with modem configuration
Thanks for you help
James
