04-15-2002 10:49 AM - edited 03-01-2019 09:18 PM
I'm bench testing a bridge setup between two 1601's,, everything works fine,, can ping from one host to another through the cisco's,, however,, when I xfer data to the far end host,,, I can only get about 17K over the line,,, ( 5 ft jumper between the units ).. either FTP or WWW,,, I can put an xover cbl to the host,, and it's just fine,, xfer 800+ K,,, but hook up the cisco's and it puts on the breaks,,, any ideas???
Thanks,,,
Todd
04-15-2002 02:03 PM
do you have fast switching enable on incoming and outgoing interfaces ?
check it with 'sh ip int serial ...' or 'sh ip int ethernet ...'
Check for CEF or FastSwitching ENABLE.
during file transfer do a 'sh proc cpu' to see what the box is doing.
do successive 'sh ip int ...' to see if there are any drops.
04-15-2002 08:24 PM
Thanks for the tip,, No,, I did not have Fast Switching enabled,, I do now, it didn't make any difference... , do I enable it on both eth0 ( connected to host ) and serial 1 ( mock T-1between routers ) ?
I enabled it on both,, when I do a sh ip int now,, it shows IP Fast Switching Enabled on both interfaces,, eth 0 and serial 1,, however,, eth 0 says IP Fast Switching on same interface disabled,, but serial 1 is enabled.. do I just need it on serial 1?
Thanks,,,
Todd
