10-13-2004 04:07 PM - edited 03-02-2019 07:14 PM
Hi there
We have 2 1710 routers and both seem to he very poor throughput. I realsi that one interface is only 10Mbps but we are only getting sustained transfer rates equivalent to 2.4Mbps through each router. When I view a graph of the port utilization while doing a large file transfer I can see that the ethernet0 port peaks from time to time at around 10Mbps but keeps dropping back to 0 every few minutes - it is this drop down to 0% utilization which is affecting the throughput I think (as opposed to max throughput not being high enough).
The routers are between our DMZ and 2 private networks. They both take part in VPNs. One is a site to site VPN and EZVPN server (for 2 different VPNs) and the other is an EZVPN client. When I deconfigure the VPNs there is no increase in performance.
Does anybody have any ideas about improving the performance or is this the best I can expect from a 1710?
Thanks - config to follow:
10-13-2004 04:08 PM
The config:
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log uptime
service password-encryption
service sequence-numbers
hostname XXXXXX
logging queue-limit 100
logging buffered 51200 debugging
logging console critical
enable secret 5 XXXXXX
username XXXXXX privilege 15 password 7 XXXXXX
memory-size iomem 25
clock timezone NZST 12
clock summer-time NZDT recurring 1 Sun Oct 2:00 3 Sun Mar 3:00
aaa new-model
aaa authentication login default local
aaa authentication ppp default group radius local
aaa authorization network default group radius local
aaa authorization network XXXXXX local
aaa session-id common
ip subnet-zero
no ip source-route
ip tcp synwait-time 10
ip domain name XXXXXX
ip name-server XXXXXX
no ip bootp server
ip audit notify log
ip audit po max-events 100
ip ssh time-out 60
ip ssh authentication-retries 2
vpdn enable
vpdn-group L2TP_Windows2000Client
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
vpdn-group PPTP_Windows2000Client
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 2
crypto ipsec client ezvpn XXXXXX
connect auto
group XXXXXX key XXXXXX
mode network-extension
peer XXXXXX
interface Loopback0
ip address 172.16.10.100 255.255.255.0
interface Ethernet0
description DMZ Interface
ip address 192.168.1.150 255.255.255.0
ip route-cache flow
ip tcp adjust-mss 1375
duplex full
no ip nat outside
interface FastEthernet0
description Internal Interface
ip address 10.4.100.50 255.255.0.0
ip route-cache flow
speed 100
full-duplex
crypto ipsec client ezvpn XXXXXX inside
no ip nat inside
interface Virtual-Template1
ip unnumbered Loopback0
ip nat inside
peer default ip address pool l2tppool
ppp authentication ms-chap
interface Virtual-Template2
ip nat inside
peer default ip address pool pptppool
ppp encrypt mppe 40
no ip nat inside source list 102 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0 192.168.1.100 permanent
ip http server
ip http authentication local
ip http secure-server
logging trap debugging
dialer-list 1 protocol ip permit
snmp-server community public RO
snmp-server location Central Node Internal/DMZ
snmp-server contact Network Adminstrator,XXXXXX
snmp-server enable traps tty
radius-server host 10.4.4.1 auth-port 1645 acct-port 1646
radius-server retransmit 2
radius-server key 7 XXXXXX
radius-server authorization permit missing Service-Type
banner motd ^XXXXXX
Access to the XXXXXX network is prohibited without the prior permission of XXXXXX.^C
line con 0
transport output telnet
line aux 0
line vty 0 4
privilege level 15
transport input telnet ssh
line vty 5 15
privilege level 15
scheduler allocate 4000 1000
scheduler interval 500
end
