Slow speed when connecting to specific VLAN
dgzbri
Hi just want to ask if I have the same problem here and if you can share your solution.
We currently segregate our pc units to specific VLAN, we create a VLAN 550 where they can only access server but no internet access.
Upon our test run on 5 pc units, when opening an application, they experience a slow response from that application. While the other units that are connected to other VLAN have fast response. Is there anyone here with the same problem? We want to migrate those pc's to VLAN 550 but since we are experiencing slow response, we might not meet our timeline. Below is the interface of our VLAN 550.
SW-DC-CORE#sh int VLAN 550
Vlan550 is up, line protocol is up
 Hardware is Ethernet SVI, address is
 Internet address is
 MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
 Keepalive not supported
 Last input never, output 21:42:22, output hang never
 Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
 Queueing strategy: fifo
 Output queue: 0/40 (size/max)
   746674 packets input, 254138836 bytes, 0 no buffer
   Received 0 broadcasts (0 IP multicasts)
   679223 packets output, 649123599 bytes, 0 underruns
   0 output errors, 4 interface resets
   0 unknown protocol drops
dgzbri
2 Accepted Solutions
g58211702
  • Bandwidth Limitation: Check if there are any bandwidth limitations set on VLAN 550. Since you mentioned that the speed is significantly slower compared to other VLANs, ensuring that the bandwidth allocation is appropriate for your applications is crucial.
  • Quality of Service (QoS): Implement QoS settings to prioritize traffic on VLAN 550. This can help improve the performance of applications by ensuring they get the bandwidth they need over less critical traffic.
  • Network Latency: Investigate if there are any network latency issues specifically affecting VLAN 550. Tools like ping tests or traceroute can help identify any delays in the network path.
  • Application-Specific Issues: Verify if the applications being used have specific requirements for performance or connectivity that may not be being met by the VLAN configuration.
  • Switch Configuration: Review the switch configuration for VLAN 550 to ensure that there are no misconfigurations. Pay attention to settings like STP (Spanning Tree Protocol) and ensure there are no blocked ports.
timo-juhani
1) You're using SVI. Check for bottlenecks in LAN port speeds i.e. is there enough capacity even on theory. You didn't mention the device type of the software therefore for safety it makes sense to suggest that CPU load should be verified as well. Figure out if your traffic is for some reason hitting the CPU. This could be the case for the more "traditional" models.
2) Do you have a firewall between the VLANs? How does it perform?
3) Are the PCs distributing equal traffic load and type when you compare the two VLANs together?
10 Replies 10
What is SW model?
MHM
Cisco C3850-nm-blank 24 port
The interface connect to device use same mtu' can you do show interface
MHM
@MHM Cisco World actually our vlans are configured inside our core c3850. mtu is 1500
Show ip traffic statistics
Check if there is any frag
MHM
can you share topology?
try same with creating new vlan
g58211702
timo-juhani
dgzbri
Thank you for all your information.
I contacted the resigned network administrator of our company, and upon checking we have a bottleneck problem on vlan1 as what @timo-juhani said. Currently we are on-going check of what and who are connected to this vlan 1.
Thank you everyone, might as well give you feedback once we solve the bottleneck at vlan 1
