Stange problem with direction of dialin
tleemans
Greetings,
I'm expiriencing a strange problem connecting to a cisco 2610.
Setup:
A -|
|- C
B -|
Routers A and B are 3640's with me in the Netherlands, Router C is in the UK. When A or B connects to C with ppp chap, packets can travel to C. However, returnpackets never reach A or B. On C I see a successfull dialer-setup, and with 'debug ip packet' I see the packet being routed to the correct interface. These packets never reach A or B.
The stange thing is: when C dials A or B all is well.
- There are no access-lists on the dialers of C.
- No crypto.
- There is no caller-id when A or B dials C (international call).
- A uses isdn-2, B isdn-30
The config of C (just for A):
interface BRI1/0
no ip address
no ip directed-broadcast
encapsulation ppp
dialer pool-member 21
isdn switch-type basic-net3
no cdp enable
ppp multilink
interface Dialer1
ip address 10.3.0.2 255.255.255.0
encapsulation ppp
dialer remote-name A
dialer idle-timeout 600
dialer string 0031xxxxxxx
dialer hold-queue 5 timeout 5
dialer pool 21
dialer-group 1
no cdp enable
ppp authentication chap
ip route 10.1.0.0 255.255.255.0 10.3.0.1
dialer-list 1 protocol ip permit
Could somebody point me in the right direction?
Thanx!
Thomas.
ebreniz
Level 6
Level 6
Try some other tools like ping and traceroute or debug ip packets with ping . Can you give more details about your problem with a diagram send as a attachment and other router configuration to understand the problem better.
