Static routing problem
Hello everyone, I'm trying to follow a tutorial about static routing. Whenever I put my next hop from ISP router to Core Router which is 200.200.200.2 all I get is an error or failed. But when I went to my Core and setup a next hop for my Border router to 200.200.200.6 I'm having a successful PDU. Is there anything wrong in my ISP router? I hope you guys can help me. The tutorial im following is this one ("static routing with Connecting 4 routers with explanation | Cisco Packet Tracer Tutorial 3 - YouTube "). And I'm currently at the 15 minutes of the video that I'm having trouble with. shot1.pngshot2.png
6 Replies 6
 Just setup a static route on the ISP and all good.
ISP#conf t
Enter configuration commands, one per line. End with CNTL/Z.
ISP(config)#ip route 0.0.0.0 0.0.0.0 200.200.200.2
ISP(config)#
How did you do that?
Hello, sir. I tried using this but I still can't ping my other PC on 192.168.1.0 ; 192.168.2.0 network from my PC on the 192.168.0.0 network.
The Access list is blocking. You dont need the static route actually You have RIP configured and this enough
 Just change RIP to version 2
router rip
Version 2
Then, take off the Access list and Ping will work
Is there any solution wherein I can keep the NAT overload and not delete the access list and still ping all my devices with each other, sir? In this activity I'm given 2 tasks. Create a NAT overload then second is to be able to ping each pc.
Sure thing. But, for NAT overload, you dont need that Access List applied on the interface:
NAT is formed by:
ip nat inside
ip nat outside
access-list
nat pool
 Try to follow this guide.
interface GigabitEthernet0/0
ip address 192.168.0.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
ip address 200.200.200.1 255.255.255.252
ip nat outside
access-list 1 permit 192.168.0.0 0.0.0.255
ip nat pool MY_POOL 200.200.200.1 200.200.200.2 netmask 255.255.255.0
ip nat inside source list 1 pool MY_POOL
