Strange high CPU utilization w/o processes that makes cpu load
hramtsov
Greetings,
Strange thing happend with our 7206VXR. It starts to utilize 40% CPU but there is no processes which loads cpu. Total router's throughput comes short of satisfactory.
router#sh processes cpu sorted
CPU utilization for five seconds: 40%/32%; one minute: 36%; five minutes: 36%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
39 504392 886343 569 6.96% 5.63% 5.42% 0 IP Input
66 3488 1164 2996 0.65% 0.05% 0.01% 3 SSH Process
136 1668 272 6132 0.40% 0.04% 0.00% 0 BGP Scanner
61 7780 6004 1295 0.24% 0.14% 0.09% 0 CEF process
5 56 304 184 0.00% 0.00% 0.00% 0 Pool Manager
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
7 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
Experimentally, I've found that CPU load become 6-7% when I shutdown interface Serial2/5 (our link to provider, bandwidth 2Mbit/s).
What can be cause of this strange behavior?
How can I fix this?
Thanks in advance.
Best regards,
Dmitry N. Hramtsov
Part of my config:
interface Serial2/5
description Leased line to Provider
bandwidth 2048
ip address x.y.189.130 255.255.255.252
ip access-group 113 in
ip access-group 104 out
ip nat outside
rate-limit input access-group 117 1000000 1500 2000 conform-action transmit exceed-action drop
ip route-cache flow
no ip mroute-cache
serial restart-delay 0
no cdp enable
end
access-list 113 deny udp any any eq 1434
access-list 113 deny ip 10.0.0.0 0.255.255.255 any
access-list 113 deny ip 172.16.0.0 0.15.255.255 any
access-list 113 deny ip 192.168.0.0 0.0.255.255 any
access-list 113 deny ip any 10.0.0.0 0.255.255.255
access-list 113 deny ip any 172.16.0.0 0.15.255.255
access-list 113 deny ip any 192.168.0.0 0.0.255.255
access-list 113 deny udp any any eq 135
access-list 113 deny udp any any eq netbios-ns
access-list 113 deny udp any any eq netbios-dgm
access-list 113 deny udp any any eq netbios-ss
access-list 113 deny udp any any eq 445
access-list 113 deny tcp any any eq 135
access-list 113 deny tcp any any eq 137
access-list 113 deny tcp any any eq 138
access-list 113 deny tcp any any eq 139
access-list 113 deny tcp any any eq 445
access-list 113 permit ip any any
access-list 104 deny ip 10.0.0.0 0.255.255.255 any
access-list 104 deny ip 172.16.0.0 0.15.255.255 any
access-list 104 deny ip 192.168.0.0 0.0.255.255 any
access-list 104 deny ip any 10.0.0.0 0.255.255.255
access-list 104 deny ip any 172.16.0.0 0.15.255.255
access-list 104 deny ip any 192.168.0.0 0.0.255.255
access-list 104 deny udp any any eq 135
access-list 104 deny udp any any eq netbios-ns
access-list 104 deny udp any any eq netbios-dgm
access-list 104 deny udp any any eq netbios-ss
access-list 104 deny udp any any eq 445
access-list 104 deny tcp any any eq 135
access-list 104 deny tcp any any eq 137
access-list 104 deny tcp any any eq 138
totally 174 lines in access-list 104
access-list 104 deny ip x.y.218.160 0.0.0.31 any
access-list 104 deny ip x.y.214.96 0.0.0.31 any
access-list 104 deny ip x.y.221.96 0.0.0.31 any
access-list 104 deny ip x.y.221.128 0.0.0.31 any
access-list 104 deny ip x.y.222.64 0.0.0.31 any
access-list 104 permit ip any any
access-list 117 deny ip any x.y.164.0 0.0.0.255
access-list 117 deny ip any host x.y.209.65
access-list 117 permit ip any any
15 Replies 15
I forget to add "sh in fa 0/0" to my previous post:
router#sh in fa 0/0
FastEthernet0/0 is up, line protocol is up
Hardware is DEC21140A, address is 0001.6369.e800 (bia 0001.6369.e800)
Description: Main Interface - Connected to N1C2P10
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 6/255, rxload 8/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1d01h
Input queue: 1/255/18278/125737 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 3417000 bits/sec, 1003 packets/sec
5 minute output rate 2493000 bits/sec, 820 packets/sec
164917387 packets input, 3312364739 bytes
Received 2422195 broadcasts, 0 runts, 2 giants, 1827 throttles
5974 input errors, 0 CRC, 0 frame, 0 overrun, 5970 ignored
0 watchdog
92712980 packets output, 1711179583 bytes, 0 underruns
0 lost carrier, 0 no carrier
As you see, input packets/sec is now 4 times lower.
Just like CPU usage. It is very strange.
Best regards,
Dmitry N. Hramtsov
