Supervisor Engine 720 ::: MIB :::
lin-d
hi,
I can't find any about Supervisor Engine 720 "MIB value" at cisco.com,any body can help me , very tks !
I need MIB for cpu ,memory ,slot cpu etc,.
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(17d)SXB10, RELEASE SOFTWARE (fc1)
pradeepde
Level 5
Level 5
Do you need to monitor cpu load here?. I think there is no Object ID available for Catalyst switches running CatOS to monitor the CPU load. The reason is that, unlike routers, switches hardly use the CPU to perform operations related to forwarding of packets, but forwarding of packets is done on hardware mainly.
If this is not your expected answer, let me know with your exact requirement.
Dear Sir :
Very thanks your help!in this Supervisor Engine 720 is running Cisco IOS and not CatOS , IOS version is "s72033-pk9sv-mz.122-17d.SXB10.bin,1" , i can catch interface inbound and outbound used snmp to creat like mrtg graph , but that's Supervisor Engine 720 have many differrent MIB value ,than i can't find about "Supervisor Engine 720's MIB value" Document , can your help me to find it ? very thank's for your help !
Best Regards,
David Lin.
dasberry
I believe this is what you are looking for:
1.3.6.1.4.1.9.1.557
Dear Sir : very thanks ! did you have any document or link for Supervisor Engine 720 "MIB value" , i need this.
Best Regards,
David Lin.
