switch 4948 - it's power down by supervisor !
arodoncea
I have the cisco switch 4948 with bellow details and i mark in red the message that are important to check.
Please advice what are the root cause at this situation and how it can be fix.
Thank you in advance for time and answer.
Toni
 * Welcome to Rom Monitor for      WS-C4948E System       *
 * Copyright (c) 2003-2011 by Cisco Systems, Inc.         *
 * All rights reserved.                                   *
 Checking the partition table and boot sector...
 Checking FAT, Files and Directories...
 Reclaiming unused space...
 Updating FAT...
 Primary Rom Monitor Version 12.2(44r)SG11 CPU Rev: 3.1, Board Rev: 8,
 Board Type: 104, CPLD Hobgoblin Rev: 21
 Chassis: WS-C4948E
 Front Panel Phy is Bcm5482s
 Got Mac Address: 58:97:bd:8b:4f:bf
 MAC Address  : 58-97-bd-8b-4f-bf
 Ip Address   : Not set.
 Netmask      : Not set.
 Gateway      : Not set.
 TftpServer   : Not set.
 Peer supervisor not detected or is not running IOS Supervisor uplinks
 and all linecards have been reset
 ***** The system will autoboot in 5 seconds *****
 Type control-C to prevent autobooting.
 ******** The system will autoboot now ********
 config-register = 0x2101
 Autobooting using the first file from bootflash.....
 Rommon reg: 0x00004780
 Reset2Reg: 0x00009EFF
 Fortooine controller 0x0B5C66C8..0x0B72EC3F original size:0x001C685D
 ################## Decompression done, relocating ...
 diagsk5 version 5.0.2.3
 prod: WS-C4948E part: 73-14926-01 serial: CAT1936S2XC
 Power-on-self-test for Module 1: WS-C4948E
 CPU Subsystem Tests ...
 seeprom: Pass
 Traffic: L3 Looopback ...
 Test Results: Pass
 Traffic: L2 Loopback ...
 Test Results: Pass
 Switching Subsystem Memory ...
 Packet Memory Test Results: Pass
 Module 1 Passed
 Rommon reg: 0x00000780
                Restricted Rights Legend
 Use, duplication, or disclosure by the Government is subject to
 restrictions as set forth in subparagraph
 (c) of the Commercial Computer Software - Restricted Rights clause at
 FAR sec. 52.227-19 and subparagraph
 (c) (1) (ii) of the Rights in Technical Data and Computer Software
 clause at DFARS sec. 252.227-7013.
             cisco Systems, Inc.
             170 West Tasman Drive
             San Jose, California 95134-1706
 Cisco IOS Software, Catalyst 4500 L3 Switch Software
 (cat4500e-ENTSERVICES-M), Version 15.1(2)SG5, RELEASE SOFTWARE (fc1)
 Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2014 by Cisco Systems, Inc.
 Compiled Mon 03-Nov-14 09:38 by prod_rel_team
  !!!! NO SUPPORTED POWER SUPPLIES DETECTED ON LOCAL SUPERVISOR  SUPERVISOR WILL BE
       POWERED DOWN!!!!
 Powering down in 10 seconds...
 10  09  08  07  06  05  04  03  02  01  00
Kallol Bosu
What is the model of power supply you are using? Can you please check the below installation guide and make sure you are running a compatible power supply for 4948-E?
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4900/4948E/installation/guide/4948E_ins/04frus.html
Kallol
Hello All,
yes thats right the power supply has to be "PWR-C49E-300AC-R"
even i have faced the same issue as my 4948E switch contained just "PWR-C49E-300AC" so the switch will shutdown,,,,, please try with PWR-C49E-300AC-R"
I hope this helps.........
