Switch Port Mapping
admin_2
Level 3
Level 3
I've been given a project that requires keeping an inventory of devices connected to ports on our Cisco 3550 Switches. I have been able to map the MAC Addresses to the ports on the switch through SNMP and the BRIDGE-MIB, however, it does not appear to list all of the MAC Addresses connected to it. Even the sho mac-add command does not list all of these devices.
I had evaluated SolarWinds Switch Port Mapping tool which does give an accurate account of all MAC Addresses which are connected.
My question would be: Does the SolarWinds tool use other methods to determine the remaining devices, or perhaps there is another MIB I could be utilizing that I am missing.
Any assistance would be appreciated. Thanks,
Marvin Rhoads
Have your tried using the Campus Manager User Tracking Tool (part of CiscoWorks LAN Management Solution)? It will inlude MAC addresses among other SNMP- and CAM table- derived information.
Unfortunately, that does not fit our budget...
But I think the problem is with the CAM "agingtime" value, which is only set to 300 seconds. I will have to look for an alternate solution.
Thanks.
