02-10-2002 08:04 PM - edited 03-01-2019 08:25 PM
I have a T1 directly connected to a corporate office which use a Citrix system. I also have a DSL line for internet connection. The T1 uses the 10.0.0.0 IP network with a subnet of 255.255.255.224. I want to send all Citrix information to the T1 and all other Internet traffic to DSL. I am not real sure how to make this work. Cisco 1700 series routers are installed for the T1.
02-11-2002 02:41 AM
If everything else for the T1 is configured you can put a static entry to the citrix server through T1 Wan ip to make yr citrix traffic utilise T1 Link.
Thanx,
Homin
02-12-2002 07:02 AM
Coporate office will not let us have that type of access to the Citrix server. Would a default route work in this situation?
02-11-2002 07:06 AM
You could consider using policy routing which will help you route based on your source IP address.
-amdcent
