Temp Sensor Alerts on WS-C3850-48U
hillary.feldt
I have a WS-C3850-48U IOS version 03.03.03SE, that's triggering temp sensor alerts in our monitoring system. See the below output from the switch:
#show environment temperature stat
Inlet Temperature Value: 24 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 41 Degree Celsius
Red Threshold : 56 Degree Celsius
Hotspot Temperature Value: 38 Degree Celsius
Yellow Threshold : 105 Degree Celsius
Red Threshold : 125 Degree Celsius
I'm wondering if there are any known bugs with this or what the fix would be. Clearly the Hotspot temp values for yellow and red are supposed to be in Fahrenheit. I'm wondering what the fix/solution is for this.
Thank you.
0 Replies 0
