Tftp upgrade problem on 2950
bweitz
I tried to upgrade my 2950 to the last ios.
I configured the ip address management and I can ping this address from my laptop.
but from the 2950 I can't ping the pc. So the 2950 can't connect to the tftp server.
My laptop use a 1000baseT nic and a usb/serial adaptator.
Any idea?
pvezina
Do you have the right Default Gateway on your 2950? Normally when you can ping from one side but you can't from the other is the default-gateway. The command line looks something like this in global configuration mode:
ip default-gateway xxx.xxx.xxx.xxx
Hope this helps.
hi,
I don't need ip default-gateway because the ip address of the 2950 and the pc are in the same range.
10.10.10.0/24 (1 and 2).
But I can try.
thanks
hi,
Find the solution. It's was my firewall.
Thanks for posting the resolution of this problem. It is very helpful to know what the answer turned out to be. Too many people find an answer and drop the thread without completion - especially when the answer was some element of their environment. I am glad that you shared your answer with us.
Rick
Rick
