03-14-2004 04:54 AM - edited 03-02-2019 02:16 PM
Excuse me , Who can tell me where to find all cisco products' output electric power?
03-14-2004 10:22 AM
What do u mean by Ouptut electirc power ?? Are you talking about inline power (power over ethernet) or did u mean the KVA ratings required for each Cisco product ? The KVA rating would indicate how much input power required for operation of that product.
03-14-2004 07:09 PM
Yes , I means the input KW of the cisco products!
I will choose the power supply and UPS for them ,So is CCO some link to gather the rating power of them?
tks
03-14-2004 09:41 PM
I doubt if there is a link where you can get all the KVA ratings for all equipments. But you can definitely search each product release notes or documentation and search in the technical specification section. I have done this before for a customer. Its a tedious task to gather this info.
Am not sure if this would be of help..but if you work for a Cisco partner you can call the Partner/Reseller Helpline number and see if they can get this information for you.
03-15-2004 06:43 AM
Thanks for your advertise, Maybe I have to gather infos one by one(Its a tedious task ) :-)
