Traffic generator for lab work
Kevin Dorrell
Level 10
Level 10
I want to generate some traffic to do some lab experiments on QoS. Can anyone recommend a good free or inexpensive (SOHO budget) traffic generator, preferably running on a PC?
Kevin Dorrell
Luxembourg
2 Accepted Solutions
Fms403
We use "IP-Load". It allows to generate UDP and
TCP Pakets by using different ports.
Simple, easy and very functional.
The Program runs under W2K.
Hi Kevin,
Yes it's a good application.
Check this out
http://www.bttsoftware.co.uk/ipload.html
You can download from here.
Ankur
Fms403
Hi Kevin,
Check this out
Ankur
Thanks guys, I shall check it out and let you know how I get on.
A colleague mentioned TFGEN, but I didn't find very much information about it. Does anyone have any experience of that?
Kevin Dorrell
Luxembourg
HI Kevin,
Hope this inf can be helpful to you.
http://www.st.rim.or.jp/~yumo/pub/tfgen.html
To download this
http://www.st.rim.or.jp/~yumo/pub/tfgen_chglog.html
But still I will say the applicatiojn in my first post is easy and works very well.
Ankur
