troubleshoot wan connection
tomredmond
any and all suggestions welcomed.
I have a remote site on a 1721 router connected to two core routers both 3660's by frame relay pvc's. One link is suppost to be a redundant link to the other. The two links are in two seperate subnets.
I can traceroute and or telnet from the core to the remote router but I cannot ping.
I can also traceroute/telnet from the remote router to the core and beyond but I can't ping.
I can ping from a pc in the core to either of the remote interfaces but a traceroute fails.
The ospf is not being shared and the ip ospf neighbor command say the state is EXSTART or down all though the neighbor id is correct.
I am happy to supply config's answer questions etc
Tom Redmond
20 Replies 20
'Can you ping across the PVC's when sourcing the ping ?
ping 52.5.84.2 sourcing from 52.2.84.1
I would also remove all parameters from the interface other than the ip address and the FR int DLCI commands , see if it works just with a bare bones config. maybe you have a spave in your PW for authentication .
I did a few pings and traceroutes to illustrate the problems. The 52.200.33.1 address at the end is a pc on our core LAN.
From that pc or any other on the LAN I can ping all the interfaces involved but I cannot traceroute to them. I can however telnet to them.
bar#ping
Protocol [ip]:
Target IP address: 52.5.84.2
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 52.5.84.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 52.5.84.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
bar#ping
Protocol [ip]:
Target IP address: 52.5.84.130
Repeat count [5]:
Sending 5, 100-byte ICMP Echos to 52.5.84.130, timeout is 2 seconds:
bar#ping 52.5.84.2
bar#trac
bar#traceroute 52.5.84.2
Tracing the route to 52.5.84.2
1 52.5.84.2 48 msec * 40 msec
bar#traceroute 52.5.84.130
Tracing the route to 52.5.84.130
1 52.5.84.130 68 msec * 52 msec
bar#ping 52.200.33.1
Sending 5, 100-byte ICMP Echos to 52.200.33.1, timeout is 2 seconds:
bar#tracer
bar#traceroute 52.200.33.1
Tracing the route to 52.200.33.1
1 52.5.84.130 64 msec 60 msec 60 msec
2 52.200.33.1 60 msec 60 msec 60 msec
Tom
If you can not ping directly connected netwrorks your OSPF will never establish a relationship.
You can trace because it is going around since the interface are up your traces are successful.
Try a few things
try clearing the CEF and or route-cache
try removing the ip helper from the serial interface
try going with a bare bones config
try making your subnet masks 30 bits
If all of this fail I would open a ticket with the FR provider telling them you are not able to pass data , .
I went with a barebones config on the primary link i.e. serial0.16 on remote router and serial1/0.134 on hq core router and I can now ping on that link.
I removed the ip helper address, ip ospf authentication-key, frame-relay compression and the ip directed broadcast. I will try add ing them one at a time and see at what point it fails but any suggestions are welcome.
it looks like you have area 0.0.0.84 connected to area 0 and at the remote router to area 0.0.0.100, which is also connected to area 0. So when the data takes the path through area 0.0.0.100 it needs a virtual link. When it takes the other path it does not. I'm not sure you can make it work this way but try making area 0.0.0.100 a virual link. Or clean it up and use area 0.0.0.84 throughout.
To make the virtual link work you will also need to specify area 0 authentication on the remote router.
