Trunk Port Monitoring
We have 8 Switches running various Vlans and thus formed like a ring. There are 5 MAN Links interconnecting these switches, remaining locations it's been connected by back-to-back ethernet cables.
All of the MAN interface connections configured as TRUNK.
We have noticed that during MAN outage the TRUNK interface showed as int up/proto up.
What is the SNMP MIB we supposed to poll to get the * real * status of MAN connection ...
Any help is really appreciated ..
regards
krk
paddyxdoyle
Level 6
Level 6
Do your switches support trunk negotation via DTP?
It sounds like you have your DTP mode set to on, so that it trunks unconditionally, even if there are problems with the line the interface will still show as trunking.
If you can, set your trunks to desirable at both ends and your syslog messages etc will reflect the true state of your interface.
I think this the Cisco recommended way.
Paddy
All of the trunks forced to dot1q
switchport mode trunk
Only controlled Vlans allowed on the trunk. All of the trunk port Gig Ethernet.
What models are your 8 switches?
PD
All the switches are 3550 running Layer 2.
Due to security & other reasons CDP has been disabled in all of the 8 switches.
regds
krk
