Urgent PfR HUB router limitations ?
Deepak Ambotkar
Can you help to recommend a Cisco router model that can support 50-60 PfR connections that we will put in the hub site?
I think it is local to the branch router and irrespective of the PE (HUB) device, is that correct?
Deepak
Leo Laohoo
Duplicate post #3.
It was posted in 3 different communities because I was not sure which community it belongs to.
Do you have answer to my question?
what do you exactly mean by 50-60 PfR connections ?
PfR just measure/monitor certain link/links based on pre specified criteria !!
