Using Route maps with multiple outside interfaces
3msands
I need to nat traffic from one vlan to multiple outside interfaces on a 6509 switch with msfc2. I think the following commands will work but I wanted to make sure. Is there a way to perform the same function with an overload command instead of a pool?
!!set the pools up for nat
ip nat pool-248 10.11.251.1 10.11.251.254 prefix-lenght 22
ip nat pool-244 10.11.247.1 10.11.247.254 prefix-lenght 22
ip nat pool-236 10.11.239.1 10.11.239.254 prefix-lenght 22
ip nat pool-232 10.11.235.1 10.11.235.254 prefix-lenght 22
ip nat pool-11 10.11.11.1 10.11.11.254 prefix-lenght 22
ip nat pool-4 10.11.7.1 10.11.7.254 prefix-lenght 22
!!establish dynamic source translation using the
!!route-map
ip nat inside source route-map MAP-248 pool pool-248
ip nat inside source route-map MAP-244 pool pool-244
ip nat inside source route-map MAP-236 pool pool-236
ip nat inside source route-map MAP-232 pool pool-232
ip nat inside source route-map MAP-11 pool pool-11
ip nat inside source route-map MAP-4 pool pool-4
!!set inside interfaces
interface Vlan12
ip nat inside
!!set Outside interfaces
interface Vlan248
ip nat outside
interface Vlan244
ip nat outside
interface Vlan236
ip nat outside
interface Vlan232
ip nat outside
interface Vlan4
ip nat outside
!!match traffic based on source and destination
!!addresses
access-list 248 permit ip 172.16.0.0 0.0.255.255 10.11.248.0 0.0.3.255
access-list 248 permit ip 192.168.0.0 0.0.255.255 10.11.248.0 0.0.3.255
access-list 244 permit ip 172.16.0.0 0.0.255.255 10.11.244.0 0.0.3.255
access-list 244 permit ip 192.168.0.0 0.0.255.255 10.11.244.0 0.0.3.255
access-list 236 permit ip 172.16.0.0 0.0.255.255 10.11.236.0 0.0.3.255
access-list 236 permit ip 192.168.0.0 0.0.255.255 10.11.236.0 0.0.3.255
access-list 232 permit ip 172.16.0.0 0.0.255.255 10.11.232.0 0.0.3.255
access-list 232 permit ip 192.168.0.0 0.0.255.255 10.11.232.0 0.0.3.255
access-list 4 permit ip 172.16.0.0 0.0.255.255 10.11.4.0 0.0.3.255
access-list 4 permit ip 192.168.0.0 0.0.255.255 10.11.4.0 0.0.3.255
route-map MAP-248 permit 10
route-map MAP-244 permit 10
route-map MAP-236 permit 10
route-map MAP-232 permit 10
route-map MAP-4 permit 10
match ip address 248
match ip address 244
match ip address 236
match ip address 232
match ip address 4
Richard Burts
If I understood better what your requirements were I would be more comfortable saying if there was a better way to do it. I am not clear that you really need to have a separate pool for each outbound interface, unless there is something in the requirements that calls for it. I am also not sure that you need separate route maps per interface, unless there is something in the requirements that calls for it.
A couple of comments about mechanics: you configure all the route-maps (... permit 10) and then you list all the match statements. If you took this and pasted it into a config you would wind up with 4 maps with no match clauses and one route map with 5 matches.
Also while I admire your attempt to make things clear by matching access lists to the interface vlan number, unfortunately access lists in the range 200-299 are for filtering Ethernet type codes not for filtering IP addresses.
Rick
good catch on the access-list number. I was trying to keep things clear and I forgot the need to remain under 100.
A bit of explaining to do here.
I have a network that have a number of multihomed machines. Unfortunatly these machines can reach the 172.16.0.0 network
via either interface. I need to hide the traffic from this network bound for the at least some of the vlans to prevent
an asymetrical routing issue where the machine attempts to respond to the traffic on another interface than it was
originally received upon.
I assumed that I would need to have the nat'd address be local to the machines subnet so that they would be able to respond
to the nat'd address without issue. I'm not sure I understand what you are saying regarding the permit statements.
Unfortunatly the cisco documentation is long on examples and short on explanations so this is a case of monkey see monkey do. :-)
Would the following config work to eliminate the need for pools?
!!establish source translation using the
!!route-map
ip nat inside source route-map MAP-248 interface Vlan248 overload
ip nat inside source route-map MAP-244 interface Vlan244 overload
ip nat inside source route-map MAP-236 interface Vlan236 overload
ip nat inside source route-map MAP-232 interface Vlan232 overload
ip nat inside source route-map MAP-4 interface Vlan4 overload
interface Vlan12
ip nat inside
interface Vlan248
ip nat outside
interface Vlan244
ip nat outside
interface Vlan236
ip nat outside
interface Vlan232
ip nat outside
interface Vlan4
ip nat outside
!!addresses
access-list 48 permit ip 172.16.0.0 0.0.255.255 10.11.248.0 0.0.3.255
access-list 48 permit ip 192.168.0.0 0.0.255.255 10.11.248.0 0.0.3.255
access-list 44 permit ip 172.16.0.0 0.0.255.255 10.11.244.0 0.0.3.255
access-list 44 permit ip 192.168.0.0 0.0.255.255 10.11.244.0 0.0.3.255
access-list 36 permit ip 172.16.0.0 0.0.255.255 10.11.236.0 0.0.3.255
access-list 36 permit ip 192.168.0.0 0.0.255.255 10.11.236.0 0.0.3.255
access-list 32 permit ip 172.16.0.0 0.0.255.255 10.11.232.0 0.0.3.255
access-list 32 permit ip 192.168.0.0 0.0.255.255 10.11.232.0 0.0.3.255
match ip address 48
match ip address 44
match ip address 36
match ip address 32
match ip address 4
I think it is making progress but still 2 issues. Access lists from 1 to 99 (where you have your access lists now) are standard access lists. To check both source and destination you need extended access lists (which is the range 100 to 199 or also the range 2000 to 2699). So you need to change the numeric range of the list numbers. Or you could consider used named extended access lists. The advantage of a named list is that you could retain the naming/numbering relationship that you were trying at first. For example ip access-list extended translate_248 for the list checking vlan 248.
The other issue is simple mechanics: you have
route-map MAP-248
route-map MAP-244
route-map MAP-236
etc followed by
match ip address 48
match ip address 44
match ip address 36
etc
what you need is
route-map MAP-248
match ip address 48
route-map MAP-244
match ip address 44
route-map MAP-236
match ip address 36
Rick
Ahh this makes a lot more sense to me. so the following should work. I'm assuming that you thought the change to an overload statement instead of a pool would work ok as well.
!!route-map
interface Vlan12
ip nat inside
interface Vlan248
ip nat outside
interface Vlan244
ip nat outside
interface Vlan236
ip nat outside
interface Vlan232
ip nat outside
interface Vlan4
ip nat outside
!!addresses
ip access-list extended translate_248 permit ip 172.16.0.0 0.0.255.255 10.11.248.0 0.0.3.255
ip access-list extended translate_248 permit ip 192.168.0.0 0.0.255.255 10.11.248.0 0.0.3.255
ip access-list extended translate_244 permit ip 172.16.0.0 0.0.255.255 10.11.244.0 0.0.3.255
ip access-list extended translate_244 permit ip 192.168.0.0 0.0.255.255 10.11.244.0 0.0.3.255
ip access-list extended translate_236 permit ip 172.16.0.0 0.0.255.255 10.11.236.0 0.0.3.255
ip access-list extended translate_236 permit ip 192.168.0.0 0.0.255.255 10.11.236.0 0.0.3.255
ip access-list extended translate_232 permit ip 172.16.0.0 0.0.255.255 10.11.232.0 0.0.3.255
ip access-list extended translate_32 permit ip 192.168.0.0 0.0.255.255 10.11.232.0 0.0.3.255
ip access-list extended translate_4 permit ip 172.16.0.0 0.0.255.255 10.11.4.0 0.0.3.255
ip access-list extended translate_4 permit ip 192.168.0.0 0.0.255.255 10.11.4.0 0.0.3.255
match ip address translate_248
match ip address translate244
match ip address translate_236
match ip address translate_232
match ip address translate_4
Thanks for all the help. This is a real life saver for me.
