vacl configuration doesn't drop traffic.
bruce.porter
I have two 6513 routers running IOS ver 12.2(18)SXD5. There are two lab environments connected via hsrp to these two machines. I need to seperate these two environments. They consist of vlans with hsrp on these two routers and subnets on other routers connected to these two routers.
The vacls below should permit the subnets associated with the vlans in one of these environments (SIT), and the other routed subnets in that environment, to talk to each other; but not the other environment. I aplied it last night and it didn't drop any external subnets. Any ideas?
vlan access-map SIT_ISOLATION_map 10
match ip address SIT_Isolation_in
action forward
vlan access-map SIT_ISOLATION_map 20
match ip address SIT_Isolation_out
action forward
vlan access-map SIT_ISOLATION_map 30
match ip address ip_any_any
action drop
exit
vlan filter SIT_ISOLATION_map vlan-list 510-512,515
ip access-list extended SIT_Isolation_in
remark *********************************
remark *** permit only SIT and CTPS subnets to talk to SIT
remark *EIGRP
permit eigrp any any
remark *metricsvr vlan 515
permit ip x.x.202.0 0.0.0.255 any
remark *FA servers vlan 510
permit ip x.x.116.0 0.0.0.255 any
remark *ASW servers and WSs vlan 511
permit ip x.x.117.0 0.0.0.255 any
remark *FA WSs vlan 512
permit ip x.x.118.0 0.0.0.255 any
remark *Routed link between Unclass_2 and FO 4506
permit ip x.x.112.172 0.0.0.3 any
remark *FO hosts vlan 550
permit ip x.x.122.0 0.0.0.255 any
remark *Link between Unclass_1 and Unclass_2 routers
permit ip x.x.112.16 0.0.0.3 any
remark *Routed link between Unclass_1 and CTPS bswitch
permit ip y.y.66.184 0.0.0.7 any
remark *CTPS hosts
permit ip y.y.82.128 0.0.0.63 any
deny ip any any
remark
remark
remark
exit
ip access-list extended SIT_Isolation_out
remark **********************************
remark *EIGRP
permit ip any x.x.202.0 0.0.0.255
permit ip any x.x.116.0 0.0.0.255
permit ip any x.x.117.0 0.0.0.255
permit ip any x.x.118.0 0.0.0.255
permit ip any x.x.112.172 0.0.0.3
permit ip any x.x.122.0 0.0.0.255
permit ip any x.x.112.16 0.0.0.3
permit ip any y.y.66.184 0.0.0.7
remark *CTPS hosts
permit ip any y.y.82.128 0.0.0.63
deny ip any any
remark
remark
remark
exit
ip access-list extended ip_any_any
remark All IP addresses - use in ACL map drop statement
permit ip any any
deny ip any any
remark
bhedlund
Level 4
Level 4
True, logging forwarded traffic is not an option.
However, you can capture forwarded traffic with 'action forward capture'.
Set up an available port on the switch as a capture port, connect a sniffer to it, and you will see all the packets matching your first two sequences.
This will show you one of two things:
1) The VACL is not working at all, ie. not forwarding or dropping anything. This will be evident if your sniffer does not see any traffic.
2) The traffic you want to drop is actually being forwarded by the VACL.
Although it doesnt show the solution it does give you greater insight into the problem.
bhedlund
Level 4
Level 4
Have you tried VACL logging??
Thanks for the FB. I looked at the description of vacl logging but it only logged dropped packets and I never dropped any. I also looked at debugs but they only seemed to show when you modified a vacl. This is the link I got when I put in a TAC. It is a pretty good description although it doesn't give an example showing a filter being applied to a range of vlans.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a0080160a7e.html
Hopefully the Cisco TAC engineer will be replying to this thread.
bhedlund
Level 4
Level 4
Thanks for responding to this problem, even though it was difficult to describe.
I took your advice and captured the forwarded traffic, after I had repaired some problems with HSRP and trunking. I was astonded to see traffic forwarded that I thought shouldn't.
There was a configuration error that I fixed by making all the vlans in the isolated network talk only between themselves as shown below. Thanks again...
action forward
action forward
action drop
exit
remark **Let any vlans into and out of the NTP server
permit udp X.X.0.0 0.0.255.255 host X.X.122.20 eq ntp
permit udp Y.Y.0.0 0.0.255.255 host X.X.122.20 eq ntp
permit ip host X.X.122.20 any
remark **Let HSRP and other multicasts work - both directions for any vlans
permit ip X.X.0.0 0.0.255.255 224.0.0.0 0.255.255.255
permit ip Y.Y.0.0 0.0.255.255 224.0.0.0 0.255.255.255
permit ip 224.0.0.0 0.255.255.255 any
permit ip X.X.202.0 0.0.0.255 X.X.202.0 0.0.0.255
permit ip X.X.202.0 0.0.0.255 X.X.116.0 0.0.0.255
permit ip X.X.202.0 0.0.0.255 X.X.117.0 0.0.0.255
permit ip X.X.202.0 0.0.0.255 X.X.118.0 0.0.0.255
permit ip X.X.202.0 0.0.0.255 X.X.112.172 0.0.0.3
permit ip X.X.202.0 0.0.0.255 X.X.122.0 0.0.0.255
permit ip X.X.202.0 0.0.0.255 X.X.112.16 0.0.0.3
permit ip X.X.202.0 0.0.0.255 Y.Y.66.184 0.0.0.7
permit ip X.X.202.0 0.0.0.255 Y.Y.82.128 0.0.0.63
etc...
