02-25-2004 03:48 PM - edited 03-02-2019 01:51 PM
I have configured 5 vlans on 6509 switch.
By default switch does inter-vlan routing between all vlans.
I want to remove one vlan from inter-vlan routing from this switch.
I have 720 Supervisor engine and IOS 12.2(SX).
How to do this?
02-25-2004 07:09 PM
There's no direct way to prevent traffic from being routed to or from a VLAN to my knowledge. The most common way of acheiving such functionality is to use inbound and outbound ACLs on the VLAN interface which block everything. This will block all traffic to or from the VLAN but permit intra-VLAN traffic.
02-25-2004 11:00 PM
If you remove the ip address on the vlan interface, then there should not be a gateway on that vlan. No gateway, no inter-vlan routing. (afaik)
