WAVE 7541 - System Fault LED is on - No alarms on system
Jacob-Harris
Community,
Just opened a WAVE 7541 and placed a config on it.  I was all set to deploy it when I noticed the System Fault LED on.
I've checked out the show alarms and show alarms history (after a fresh reboot), and all is good (no alarms).  Power supplies are good, memory is correct.  I'm stumped.  Anyone know why the LED won't turn off?
I have a TAC case open on this and will post the solution if we find one.
Ganesh Hariharan
Community,
Hi Jacob,
If system fault LED is on , system has discovered some fault. Check out the below link from cisco for more details
Troubleshooting system Hardware
Hope it Helps.
-GI
GI,
Thanks for the share! I've been through that document at least twice.. no luck.  Everything on the system checks out clean, no alarms in a show alarm or show alarm history.  A peer of mine mentioned he'd seen this before, and there was a hidden command needed to clear the LED??
Waiting on TAC to figure it out.
Thanks!
