08-29-2006 11:07 PM - edited 03-03-2019 04:44 AM
Hi ,
I am getting several errors on serial interface.Please help
Serial1/0 is up, line protocol is down (looped)
Hardware is DSXPNM Serial
Internet address is 2.6.8.6/30
MTU 1500 bytes, BW 44210 Kbit, DLY 200 usec,
Encapsulation PPP, LCP Listen, crc 32, loopback not set
Keepalive set (5 sec)
Last input 00:00:12, output 00:00:12, output hang never
Last clearing of "show interface" counters 00:08:58
Input queue: 0/4096/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/4096 (size/max)
220 packets input, 3080 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
9 input errors, 9 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
220 packets output, 3080 bytes, 0 underruns
0 output errors, 0 collisions, 11 interface resets
0 carrier transitions
DSU mode 0, bandwidth 44210, real bandwidth 44210, scramble 1
regards
Neo
08-29-2006 11:13 PM
Currently the link is in looped state.
Have you introduced any loop to check the Leased line?
-VJ
08-29-2006 11:15 PM
yes its in looped state, i am currently testing the link.what i am more concern is abt the CRC errors and Interface resets ??
regards
Neo
08-29-2006 11:41 PM
For CRC and interface errors, you need to check the layer 1 completely end to end.
Check the physical layer connectivity throughly.
-VJ
08-29-2006 11:44 PM
Interface resets and CRC errors are inter related ?
regards
Neo
08-29-2006 11:50 PM
Not exactly, but Both errors indicates a bad physical layer connectivity.
Interface reset counter indicates the number of times the interface has gone down completely and came back.
-VJ
08-29-2006 11:13 PM
Hi.
I think, when you use encapulsation PPP, it wil not give you "Loop" status on router's serial interface , as you past in post.
I think you need to check physical layer
1) check physical cable
2) check encapsulation both side
3) check controller status, any alram received ?
I think this will help you ..
-Minu
08-29-2006 11:44 PM
Hi Minu,
Encapsulation has no relationship with detecting loop in the link.
I think what you meant is, when we have HDLC encap on the serial link and introduce a loop in the network, the serial link status will come as "serial up/line protocol up"
In this stage, you can ping the serial interface ip address, which will travel down the physical layer path gets looped and come back. This is generally used to test the stability of the link.
Whereas when you have the encap as ppp and loop the link, the line protocol will not come up.
Hope this clarifies.
-VJ
08-30-2006 12:17 AM
do one thing just reboot the modem then check the connectivity from mux, it will becouse of wic or lese line issue & but still this interface reset comes when the errors are too much
