02-14-2005 07:17 PM - edited 03-02-2019 09:39 PM
I have a customer who is not using multicast. We do not plan to implement it.
We are running 6509, 4506 and 3750 as our switches. What happens to multicast traffic at the switch when we have not defined anything?
- No forwaring?
- all ports forwarding?
02-15-2005 01:05 AM
Flooding to all ports, which can bring your network into troubles in a case of huge multicast traffic.
See
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB?cmd=pass_through&location=outline@^1@@.ee93165/7#selected_message
for a workaround solution example.
Milan
02-15-2005 07:08 AM
I am unable to get to the reference site. Has it been correctly named?
02-15-2005 07:16 AM
You will not get there by simply clicking the URL because the URL is incomplete (essentially it looks like there was line wrap when the answer was submitted). Look beyond the indicated URL and make sure that you paste all of that text into your browser and it should get you there.
Rick
02-15-2005 07:20 AM
So in designing, what is a best practice when multicast is not being used/planned for?
02-15-2005 11:27 PM
Aa far as multicasts are not being used/planned, I wouldn't care too much about them.
If you want be "paranoid", you can prevent their flooding using IGMP, CGMP as discussed in http://www.cisco.com/warp/public/473/38.pdf
http://www.cisco.com/warp/public/473/22.pdf
Some other multicast documents:
http://www.cisco.com/warp/public/732/Tech/multicast/multicast_techdoc.shtml
Milan
