01-20-2004 04:03 AM - edited 03-02-2019 01:01 PM
Hi Guys,
we have following problems
Hard- Software
Hardware: 7206
Software: 12.2(7c)
Problem description:
After the x25 vc is terminated the isdn connection doesn´t go down.
We have configured the isdn idle timeout with 30 sec.
and the fast idle timeout is 5 sec.
Our router is configured with encapsulation x25 dte. The connection is established from our router.
No disconnect messages is send from the other site.
What can we do does the line goes down?
The idle timeout has no function in our configuration.
thx Dieter
01-23-2004 08:25 AM
check whether X.25 application which you are using any packet to be send out using debug ip packets using some access-list . find out the packets causing the line to stay up . Applying an access-list to block if its unwanted traffic .
01-25-2004 11:34 PM
Hi vmoopeung,
the x25 vc is down, no x25 traffic is going over the link.
The command show x25 vc bringing no output.
Intresting traffic can´t specified for x25 traffic.
