xyplex terminal server with cisco router problem (display problem)
cmn
hi all
i am have configured xyplex terminal server as access server to ciso router. its connects to router
but problem is when i run commands like "sh int" or any commands which display more the 15 lines.
its not dispalying after 15 line. i don't know problem with router seting or terminal setting.
thanks
chandra
ciscomoderator
Community Manager
Community Manager
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
dhester
I am having a very similar problem. I determined that my problem was with the built in pager (more). If I set "term length 0" and do "sho int", I get all the information. If I leave term length at 24, and the pager tries to pause the display to wait for input, it stops completely. It usually doesn't display the ----more--- line. I am assuming that this is some kind of terminal emulation problem, but I haven't been able to figure it out.
