1750 with NAT Issue
sir i have a 1750 with below configuration and facing a problem like it stops the internet access for the 15 users on the lan which are connected through the nat on the router after reloading the router it again works for a while but stops the surfing again after 1 or 2 hours
the router is having foll specifications :-
IOS (tm) C1700 Software (C1700-Y-M), Version 12.1(2), RELEASE SOFTWARE (fc1)
cisco 1750 (MPC860) processor (revision 0x501) with 12288K/4096K bytes of memory
4096K bytes of processor board System flash (Read/Write)
System image file is "flash:c1700-y-mz.121-2"
Kevin Dorrell
Level 10
Level 10
Could you post the config please?
Kevin Dorrell
Luxembourg
net_wiz73
from your description its clear that NAT is working but stops. This is in all probablity an issue of how the NAT tables clearance timer is set on your router. If the timer is set to never it may be hogging your memory and preventing new transaltions from being set up. Try and set the timer to clear old nat transaltion entries after say 10-12 hours.
The relevant commands are
ip nat translation tcp-timeout < secs >
ip nat transaltion udp-timeout < secs >
