24 bit subnet mask under a 30 bit masked interface
csbowser
Greetings. I have a lab that now requires a routed interface. The setup works like this. A router with a class A address and 24 bit mask (ex. 21.6.225.254/24) has an attached Catalyst 4006 with a L3 card. All lab nodes were configured on the same network, same subnet mask. Static routing. If I change the router mask to 30 bits (21.6.225.254/30) and assign 21.6.225.253/30 to one subinterface on the catalyst - what happens?
That is, I'd like to avoid changing the subnet masks on each lab node. So if they remain at a 24 bit mask, is this a problem? I would need to give the lab vlan an interface, so I'd be adding a 21.6.225.x/24. So the catalyst would have, for example, int Gig3.1 21.6.225.253/30 and int Gig3.2 21.6.225.250/24. Would this work?
JOSH GANT
"So the catalyst would have, for example, int Gig3.1 21.6.225.253/30 and int Gig3.2 21.6.225.250/24. Would this work?"
No. The 21.6.225.0/24 subnet, and the 21.6.225.252/30 subnet overlap.
I am also not quite sure what you need to do. Do you want to split the 21.6.225.0/24 network? Perhaps 21.6.225.0/25 and 21.6.225.128/25?
Trouble is, the upstream router isn't mine, and neither are the lab nodes. So I have to try and fix their problems in my limited sphere. I know the 24 and 30 bit networks overlap, I just didn't know if I could trick the box into letting me do it..
on the same box, you can not have address/mask overlapping. The device won't accept it and will give you an error message.
mberrocal
you would still need to change the default gateway of all the lab nodes, wouldn't you?
Is this what you have:
router(.254)-------/24-------cat4006-------/24-------(.x)labnodes
and labnode's default gateway is the router right?
so the catalyst 4006 is working only at layer 2.
now you want the cat4006 to route, right?
solution 1:
change router ip
router(y.z)-------/30-------(y.z-1)cat4006(.254)-------/24-------(.x)labnodes
if you can't change the router ip then you could:
router(.254)-------/30-------(.253)cat4006(.126)-------/25-------(.x)labnodes
but restricted to 0 < x < 126
is that clear???
